F2-221
Version 4.2.07-2012241608
Hello all,
I'm attempting to run qbittorrent/openvpn via docker
- https://hub.docker.com/r/markusmcnugen/qbittorrentvpn
I am unable to access /dev/net/tun/
ERROR: Cannot open TUN/TAP dev /dev/net/tun: No such file or directory (errno=2)
I have attempted to run the docker command with --cap-add=NET_ADMIN, --cap-add=SYS_ADMIN, --device=/dev/net/tun/ including multiple combinations of each.
I am only able to get the container functional by using --privileged however after a system reboot or restart of the container I receive the same error.
All docker run commands have been issued via root ssh. Container logs and docker run script below. Any help would be appreciated.
2021-01-01 18:12:46.655578 [info] VPN_ENABLED defined as 'yes'
2021-01-01 18:12:46.932939 [info] OpenVPN config file (ovpn extension) is located at /config/openvpn/us_washington_dc-aes-128-cbc-udp-dns.ovpn
dos2unix: converting file /config/openvpn/us_washington_dc-aes-128-cbc-udp-dns.ovpn to Unix format...
2021-01-01 18:12:47.136605 [info] VPN remote line defined as 'us-washingtondc.privacy.network 1198'
2021-01-01 18:12:47.193426 [info] VPN_REMOTE defined as 'us-washingtondc.privacy.network'
2021-01-01 18:12:47.253230 [info] VPN_PORT defined as '1198'
2021-01-01 18:12:47.309790 [info] VPN_PROTOCOL defined as 'udp'
2021-01-01 18:12:47.368012 [info] VPN_DEVICE_TYPE defined as 'tun0'
2021-01-01 18:12:47.425603 [info] LAN_NETWORK defined as '192.168.86.0/24'
2021-01-01 18:12:47.483039 [info] NAME_SERVERS defined as '8.8.8.8,8.8.4.4'
2021-01-01 18:12:47.538035 [info] VPN_OPTIONS not defined (via -e VPN_OPTIONS)
2021-01-01 18:12:47.595363 [info] Adding 8.8.8.8 to resolv.conf
2021-01-01 18:12:47.669936 [info] Adding 8.8.4.4 to resolv.conf
2021-01-01 18:12:47.722224 [info] Starting OpenVPN...
Fri Jan 1 18:12:48 2021 WARNING: file 'credentials.conf' is group or others accessible
Fri Jan 1 18:12:48 2021 OpenVPN 2.4.4 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] built on May 14 2019
Fri Jan 1 18:12:48 2021 library versions: OpenSSL 1.1.1 11 Sep 2018, LZO 2.08
Fri Jan 1 18:12:53 2021 TCP/UDP: Preserving recently used remote address: [AF_INET]*ip removed*:1198
Fri Jan 1 18:12:53 2021 UDP link local: (not bound)
Fri Jan 1 18:12:53 2021 UDP link remote: [AF_INET]*ip removed*:1198
Fri Jan 1 18:12:53 2021 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Fri Jan 1 18:12:53 2021 [washington405] Peer Connection Initiated with [AF_INET]*ip removed*:1198
Fri Jan 1 18:12:54 2021 OpenVPN ROUTE6: OpenVPN needs a gateway parameter for a --route-ipv6 option and no default was specified by either --route-ipv6-gateway or --ifconfig-ipv6 options
Fri Jan 1 18:12:54 2021 OpenVPN ROUTE: failed to parse/resolve route for host/network: 2000::/3
Fri Jan 1 18:12:54 2021 ERROR: Cannot open TUN/TAP dev /dev/net/tun: No such file or directory (errno=2)
Fri Jan 1 18:12:54 2021 Exiting due to fatal errorCode: Select all
docker run --privileged -d \
-v /mnt/md0/public/docker/qbittorrent/config/:/config \
-v /mnt/md0/public/docker/qbittorrent/downloads/:/downloads \
-e "VPN_ENABLED=yes" \
-e "VPN_USERNAME=username" \
-e "VPN_PASSWORD=password" \
-e "LAN_NETWORK=192.168.86.0/24" \
-e "NAME_SERVERS=8.8.8.8,8.8.4.4" \
-e "PUID=0" \
-e "PGID=0" \
-p 8080:8080 \
-p 8999:8999 \
-p 8999:8999/udp \
