afp/smb password macos finder issue.
Chicken Dinner
Post by Chicken Dinner »
I have a new F4-210 - 4-bay.
Completely new to NAS.
Macos Big Sur.
Everything seems to be working fine through my browser but I cannot access via finder in macos.
Both afp://xxxxx and smb do not seem to recognize my password - which is input from keychain.
Both afp and smb file services are enabled in TOS Control Panel.
I have also tried copy/paste the username and password from safari passwords with the same result.
Any ideas what the problem might be?
TMS
Re: afp/smb password macos finder issue.
Post by TMS »
Clean up the browser cache, restart SMB and AFP services, if you still can’t connect, please tell us what error is prompted, it’s best to take a screenshot
Chicken Dinner
TMS wrote: ↑01 Jan 2021, 22:41 Clean up the browser cache, restart SMB and AFP services, if you still can’t connect, please tell us what error is prompted, it’s best to take a screenshot
Assuming restart services means uncheck and then apple and then recheck and apply - done.
Assuming you mean my macos browser - done.
No change.
When I click "Connect" there is about a 2 second period and then the box moves side to side to indicate it hasn't been accepted.
Can other devices use AFP/SMB services successfully?
Chicken Dinner
TMzethar wrote: ↑02 Jan 2021, 21:22 Can other devices use AFP/SMB services successfully?
Seems to connect on Ipad.
No indication that it is refusing the user/pass.
I can see a "share" folder.
When I click the folder it says
"Content Unavailable
The folder contents could not be displayed because fo an unknown error."
Please send an email to support(at)terra-master.com,we can let our engineer check it remotely.
Chicken Dinner
I performed a factory reset and it now works as it should in this regard.
Return to “File Services”
