How to install Calibre in Docker?
Discussion about Docker
Calibre is a free e-book creation and reading software.
Applicable Model:
X86 models: F2-220, F2-221, F2-420, F2-421, F4-220, F4-221, F4-420, F4-421, F5-220, F5-221, F5-225, F5-420, F5-421, F5-422, F8-421, F8-422.
Not suitable for ARM models.
Compatible TOS version: all TOS version for X86 models.
Instructions:
1. Please create a shared folder named as books on TOS webpage, a subfolder named such as File1 should be created too. The share folder books should be mapped with Windows.
2. Please download and install Calibre on your computer, and click Calibre Library to set the location as the following picture shows, metadata.db would be generated.
3.Input calibre at Registry under Docker to search and download the suitable image.
4. Check the downloaded image and click Launch, the File/Directory and Loading path should be specified.
File/Directory: /mnt/md0/books/file1
Loading path: /mnt/md0/books
5. Go to Container - Details- Overview to find the tcp port.
6. Enter the TNAS IP address with the tcp port (such as https//192.168.8.10:44825) to use it.
7. The default login username is admin with the password admin123.
Return to “Docker”
