F2-210 Proxy Address?
caleb2003
Post by caleb2003 »
I have added a proxy server setting on the 210 but my IP as shown on the summary popup on tnas desktop shows my normal ISP Ip address.
How can I tell if the 210 has correctly connected via the proxy?
Re: F2-210 Proxy Address?
Please SSH access your TNAS as root, and use the cmd line traceroute to check whether the IP address of the proxy server is passed.
caleb2003
Post by caleb2003 »
Traceroute just hops directly to router address and ISP ip etc no Proxy. The proxy settings are pictured..
Imagehttps://ibb.co/d55j489
The proxy server for the HTTP proxy is probably impossible to test.
caleb2003
Post by caleb2003 »
Ok, so I tested by adding a test torrent in Transmission which leaked my ISP IP address. How do I set this proxy to work properly, if it can?
caleb2003
Post by caleb2003 »
Please let me know if there's anything further I can do, does the proxy feature work on this box at all? If not I should probably return it
You can use the following command to check whether the connection is correct after opening the proxy,
Command: ter_wget www.baidu.com
If your proxy server is displayed at position 2 in the figure below, it means you have successfully connected.
caleb2003
Post by caleb2003 »
i get Image Never resolves https://ibb.co/rkjCcPW
it has shown that the connection is successful but no response is received.
You can change other websites you can use and try, for example: ter_wget www.google.com
caleb2003
Post by caleb2003 »
google is same. If its reporting successful how come a test torrent in transmission reports my ISP address?
Return to “Network”
