Google Sync not working
jamesn
Post by jamesn »
It does the initial connection and task setup, then will sync a first time, then will not sync afterward!
jamesn
Re: Google Sync not working
Post by jamesn »
created a folder through Google Drive web access, and the folder does not appear on the T2. I created a file on the T2, but it synced the text file. Created a folder on the T2, but did not reflect the change on Google Drive web. I have tried all these things, while stopping/starting the sync task.
Please advise your TNAS model number and current TOS version, also the size of the files and folder at your Google Drive.
Return to “CloudSync”
