Plex server only partially working now?
walmanbe
Post by walmanbe »
Hi All,
I have been using Plex for years now and have recently upgraded to a new TNAS server F5-221 with currently 3 drives out of the 5 being filled right now.
Plex is at version 1.20.5.3600
When I first set it up, it seemed to be working fine. Last week I noticed some funky thing with it.
Now I am at a point where it only shows the thumbnails for a fraction of what I have. The other titles show a blank gray square with the name of it below it and the year or # of seasons. But when I click to view those files, I get the error
"There was an unexpected error loading this item"
Now I have tested the video files on the drive themselves and they work. What is going on?
Also when I tried to do a test of a new Library and add say just one folder it will not see it.
Why is this happening? Any thoughts? It is very frustrating.
Thank you.
Bryan
walmanbe
Re: Plex server only partially working now?
Post by walmanbe »
Also when I did a test to grab that same folder on the old server on my laptop it found everything no problems. So i think there is an issue with the NAS server I created?
Would it be best to delete it? and start fresh? Or is there an issue with the program version?
Thank you.
B
You can reset it, and add the library again to see whether it's ok.
walmanbe
Post by walmanbe »
I have tried the reset in the program on TOS.
Should I remove the library and create a new one? then too?
Thank you.
Bryan
You can just rename the library and try to create a new one.
walmanbe
Post by walmanbe »
I have tried renaming the bad library and created a new one.
No videos files are being found now, even though I had the location to the same folder. Also I can not delete the old Library.
The existing libraries would be erased when resetting it on Plex like the following picture shows:
walmanbe
Post by walmanbe »
I have clicked on the "RESET" button, but all the existing libraries are still there when I go into PLEX.
You are saying that it should erase all of those? For a fresh start?
No luck there.
Thoughts?
Thank you,
Bryan
{L_BUTTON_AT}walmanbe
If you do not care the existing library, try delete the whole plex folder and try again.
walmanbe
Post by walmanbe »
I tried deleting it from inside PLex. But it does not disappear. How do I erase the TNAS server I created and create a new one? The server running off my laptop works fine.
Thank you.
Return to “Plex Media Server”
