Phpmyadmin Default login password
Using Web Server, PHP, MySQL, MariaDB.
dljasani14
Post by dljasani14 »
Hello friends... New to community.. Installed phpmyadmin application to my new terramaster NAS ..But not able to login to phpmyadmin mysql.. used login : root / admin with password: password or empty.. NOT working.. Any help will be appreciated ..Thanks
Re: Phpmyadmin Default login password
Please try with username: root and password: admin to see whether it's ok.
koangminh
Post by koangminh »
- Same problem, user: root and Pass: admin can't login
And I Install PHP 7.3 but can't access
Please help!
dljasani14
{L_BUTTON_AT}TMSupport
Tried using Login id: root and password: admin
Still NOT working.
Any id pw combination giving me error :
mysqli_real_connect(): (HY000/1045): Access denied for user 'root'@'localhost' (using password: YES)
Tried uninstalling and reinstalling. tried installing PHP 7.4 and also older versions. Still same issue !
dljasani14
Finally figured it out.
You need to install "MariaDB" first. Which has default id: root and password: admin.
Then after installing MariaDB change default password to whatever you like OR keep it admin and then use the same credential ( id: root and password: admin or if you have changed it then changed one) for Phpmyadmin. It will work. !! :)
darrendemers12
Australia
Post by darrendemers12 »
Hi there! I'm new to the community and installed phpMyAdmin on my Terramaster NAS. However, I’m unable to log in to MySQL using the root/admin username with the password as 'password' or leaving it empty. Any help would be greatly appreciated! Thanks in advance!
TMbuddy
Post by TMbuddy »
darrendemers12 wrote: ↑11 Feb 2025, 20:46
Hello, thank you for contacting TerraMaster!
Please try installing "MariaDB" first. After enabling and launching the application, you will find the default username: root and password: admin.
Return to “Web Server/PHP/MySQL/MariaDB”
