System logging and graphing
justsimon
Australia
Post by justsimon »
Can you make an app or feature to show graphs over time, with a user-selectable date range would be great.
I would love to see (if these are available):
  • HDD Temp
  • Read
  • Write
  • Fan speed
  • CPU temp
  • CPU usage
  • Motherboard temp
  • LAN Speed In
  • LAN Speed Out
The logs might already be stored somewhere.
At the moment I'm trying to figure out if this can be done with docker, but a native app would be great.
Or if any other owners can suggest docker containers for the above, it'd be much appreciated!
justsimon
Australia
Re: System logging and graphing
Post by justsimon »
So you have Netdata available as an app, but it's dated 2019-10-23.
When I load it up at host:19999 it prompts me to update it.
Will I screw things up if I try to update it via ssh?
justsimon
Australia
Post by justsimon »
And can you tell me where it's installed?
I want to tweak the config files to increase the log size and pull in more info via python.d
demetry14
Post by demetry14 »
Have you considered monitoring your NAS with Docker > Prometheus Traefik.
https://blog.leopoldjacquot.com/monitor-your-nas/
Demetry
F2-210
F4-210
We plan to add more info on the sysinfo board, so that you can have such info easier.
justsimon
Australia
Post by justsimon »
That would be great!
Is there there any concern with installing Linux apps via CLI?
I was wondering if I could just install netdata directly, but concerned it might mess with TOS
