Koofr App
mladams7259
Koofr App
Post by mladams7259 »
I cannot get the Koofr app to work for any of my accounts. I have 2 that use google login and 1 that just uses a username/password login. I have tried to login to both types with no success. I always get error "operation failed" after about 45-60 seconds of waiting. I have also tried creating a webdav password through koofr and it will not work either. I cannot get past the login screen to do anything. I have attached a screenshot with the same error i get on each login attempt
TMS
Re: Koofr App
Post by TMS »
Thank you for your report, we will verify it.
Return to “CloudSync”
