TD2 thunderbolt 3
David besançon
TD2 thunderbolt 3
Post by David besançon »
I try to connect a HDMI screen ton the MINI diplay port, so i use a "mini-diplay port to HDMI" connector... but no result, can you help me ?
And otherwise, I am surprised that my T2 have "mini" display port 1.4 ... it should be Diplay port 1.2 (Not MINI) !!!
David besançon
Re: TD2 thunderbolt 3
Please someone who can tell me what "mini display port to HDMI" adapter is compatible with my terramaster D2 thunderbolt 3 ???
I try 2, one from Apple ... doesnt work, and one from belkin ... doesnt work
Help please, THX
Hi. Actually, it's DP1.2 but not HDMI mini.
David besançon
Please believe me its "mini display port 1.4"
To convince you i toke a photo i put it in the post
I just want to use the mini display port with mini display port ---- Hdmi connector to connect a hdmi connector
You can read this to anderstand:
viewtopic.php?f=66&t=464
I trry now 3 differents connectors and the 3 doesnt work.
Please help
David besançon
Correction to my last post :
I just want to use the mini display port with mini display port ---- Hdmi connector to connect a hdmi MONITOR
Please help
As this is a new mini DP1.4 port, we don't recommend dp-hdmi adaptor, you better connect direct to a dp minitor.
David besançon
Thx for the Reply, so i have 2 questions :
1 - what kind of "mini dp to dp" cable should i by to be SURE that will work ? can you give me a link to buy it please ?
2 - I buy the "TD2 thunderbolt 3 (not plus)" with DP 1.2 and I receive the "TD2 thunderbolt 3 (not plus)" with miniDP 1.4,
is it normal ?
Is it a "new" model ?
Like a mix between
this model :
https://www.terra-master.com/fr/product ... olt-3.html
and this model :
https://www.terra-master.com/fr/product ... -plus.html
Are you shure that the controler of DP on my TD2 is 1.4 and not 1.2 ?
Thank you
Not, I am sure your model was not mixed UP with plus model. Just The TD2 Thunderbolt 3 has new version in this year, and the web info has not been updated.
And I am sure it is DP1.4.
David besançon
Ok
So what kind of "mini dp to dp" cable should i buy to be SURE that will work ? can you give me a link to buy it please ?
MIchaelSchaa
Post by MIchaelSchaa »
I just bought this one and it work fine with my Macbook Pro 15 inch and my Dell monitor.
https://www.amazon.de/gp/product/B07R6P ... UTF8&psc=1
Best
Michael
