Cut and Paste failing with NAN%
PaulWarner
Post by PaulWarner »
I am trying to cut and paste within folders on the NAS drive. Almost all of the folders cut and paste fine, but a small percentage result in a NAN% display in the copy progress bar, and eventually the copy completes, but the folders never get moved. What is causing this?
TMS
Re: Cut and Paste failing with NAN%
Post by TMS »
PaulWarner wrote: ↑06 Dec 2020, 02:58 but a small percentage result in a NAN% display in the copy progress bar, and eventually the copy completes, but the folders never get moved.
We will verify and troubleshoot. Is the phenomenon caused by cutting and pasting empty files or folders?
What's model and TOS version please?
PaulWarner
I Have the F5-221. Thanks for looking into this.
XSPC77
Post by XSPC77 »
Hi I am having the same issue.. help please.
TMS
Post by TMS »
Cut and paste an empty file/folder showing NAN%, it is a success.
jimconsole
Post by jimconsole »
I just had this same issue and the problem was because the files i was transferring had symbols like ' and " etc.. in the titles. example: John's Photos. As soon as i removed them from the files and folders i could then transfer fine. So John's Photos now becomes Johns Photos.
{L_BUTTON_AT}jimconsole
Which version of TOS is it?
jimconsole
TMRyan wrote: ↑04 Apr 2021, 19:55 Hi, Which version of TOS is it?
Hi, I'm using a F4-210 with TOS Version 4.2.08-2101111540
Return to “File Services”
