Plex cannot find shared folder
Vika09
Post by Vika09 »
Hi there,
I recently installed Plex on my Naz F4 –220.
After installing Plex I tried to set up my media folders within Plex however I am not able to find the shared folders that I set up on the TOS software. I am only able to find these folders as per the screenshot below:
https://imgur.com/a/CGpd15n
How do I make sure that Plex can see my shared folders that I set up as per the screenshot below:
https://imgur.com/a/6wsj229
Re: Plex cannot find shared folder
Hi.
The shared folders is under the /mnt/md0 amd /mnt/md1. You must select the shared folder or the directory under it, otherwise the content cannot be searched.
Vika09
Post by Vika09 »
Oh wow! Thank you for the fast response!
It works!
Return to “Plex Media Server”
