Single Disk Configuration
sianderson
Post by sianderson »
So with recent stability issues, my configuration is now as follows on my F2-210 both as single disk configuration
Bay 1 = 500Gb Hard Drive
Bay 2 = 6Tb Hard Drive (where all my data is stored)
I understand that TOS is installed on my 500Gb hard drive and runs from that (or is it now installed on both?) i set it up with just the 500gb drive in and it was stable under 4.2.07 then added the 6Tb after
what happens when I want to upgrade the 500gb to a new drive, can I just pull it out and put the new drive in and the device will boot up as normal or would it see it as a brand new unit?
F2-424 TOS 7.0.1140
F2-423 TOS 7.0.1140
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
Re: Single Disk Configuration
You just need to check if your TNAS still works properly after you remove your 500GB drive.
sianderson
Ok so that’s the theory, the os is installed on both drives?, so if I pull the 500gb it should boot normally with just the 6TB and still have all my apps and configuration set up?
F2-424 TOS 7.0.1140
F2-423 TOS 7.0.1140
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
Normally, the answer is YES.
