How to enable .htm or .html files in the webserver
Using Web Server, PHP, MySQL, MariaDB.
stapetz
Post by stapetz »
Hi there,
per default only .php files are processed in the webserver. This is also shown as a message on the TOS Desktop in the configuration app for the webserver.
Where can I enable, that also .html or .htm files will be delivered from the server and where do I tell the system that the default file in a directory should be the index.html?
I connected via ssh to the NAS and I found the http.conf, but I don't know a) whether this is the right file to edit and b) what I have to add in the file and c) how I have to restart the webserver that all changes take effect.
Thanks in advance,
Stefan
TMS
Re: How to enable .htm or .html files in the webserver
Post by TMS »
Do you want to see your own .html file on the website, if so, just put the .html file in the root directory of the website (default is appdata/), click the link to open it.
Return to “Web Server/PHP/MySQL/MariaDB”
