[Help] Access History Error -
Nikdfish
Post by Nikdfish »
My system consists of a F2-423 running TOS 7.0.1536. It has 20GB RAM, 2 NVMe btrfs drives as JOB (volume1) and 2 Toshiba 12TB ext4 as TRAID (volume2). A D4-320 with 4 Ironwolf 8TB ext4 drives as TRAID (volume3) is attached directly to the F2-423 with a short cable rated for 10Gbps. A powered USB 3.2 hub is attached to the F2-423 with a short cable rated for 10Gbps. Two USB 3.2 SATA docks are attached to thte hub. There is one 6TB NTFS drive seated in each dock.
I recently have had multiple instances of drive errors on volume 3 component drives occuring while copying a large volume of files (close to 2 TB) from volume 3 to one of the external 6TB drives. The errors are disk access history I/O errors. These errors are not reflected in the ironwolf health management reports. These errors generally are cleared by a restart of the NAS, but I have seen them clear without a reboot.
Once a couple of drives get flagged with this error, the volume becomes inaccessible and is flagged as "corrupt". On restart, the errors are cleared and the volume shows normal, healthy and accessible.
While trying a subset of the original copy list after a restart I again saw the error appear. When I checked the monitor attached to the F2-423 I saw this:
the storage manager disk tab showed this:
at that point in time, volume 3 was not accessible and the copy process stopped.
However, without any action on my part, within a few minutes the errors disappeared from the storage manager disk tab and volume 3 was accessible & showed as healthy.
I'm thinking the issue is probably related to something in the USB layer, the drives themselves would seem to be OK. During normal operations, including 1TB+ PC backups, I have not been seeing this happen. It only seems to appear when I am doing a large, time consuming, block of non-network, file transfers.
Any suggestions regarding the mechanism at fault or how to avoid an occurrance would be appreciated. I would like to blame the hub or docks, but the errors only pop up on the D4-320 drives.
F2-423 TOS 7.0.1536 20GB RAM, 2x NVMe drives (.25TB + 1TB JBOD as Volume1), 2x 12TB TRAID as Volume2 D4-320 4x 8TB TRAID as Volume3
