[Help] [Resolved] My Jellyfin 10.11.11.04 broken  [SOLVED]
Discussion on Jellyfin media server, clients
Nikdfish
Post by Nikdfish »
This morning I found Jellyfin 10.11.11.04 alternating between enabled & disabled every few seconds. Manually disabling the app would appear to work, then the app would would start back in the enabled/disabled sequence. The only way to stop it was to uninstall the app.
I tried reinstalling via the app center, but the issue reappeared. I also tried a manual install using a downloaded copy of the 10.11.11.04 file. During the install process, there were multiple occasions when "installation failed" appeared, but then the install resumed & eventually completed. The issue then reappeared again.
I am currently on TOS 7.0.1422. The equipment is a F2-423 with 20GB RAM and two 12TB drives in a TRAID. A D4-320 with four 8TB drives is attached.
As recently as yesterday, Jellyfin was running fine.
The initial 10.11.11.04 update from 10.11.10 had resulted in the need to redo the app's configuration from scratch, but the system was working properly once that was done.
Any suggestions would be appreciated
ETA ... This provided impetus to finally try to learn how to install a docker image. Currently going through configuring Jellyfin 12.4
Jellyfin 12.4 now running properly in a docker container.
F2-423 TOS 7.0.1536 20GB RAM, 2x NVMe drives (.25TB + 1TB JBOD as Volume1), 2x 12TB TRAID as Volume2 D4-320 4x 8TB TRAID as Volume3
Return to “Jellyfin Media Server”
