Curl, screen and Rclone
jhdscript
Post by jhdscript »
Hello all,
i m looking to install rclone because i dont find it in TOS. When i logged into root using ssh i cannot use curl to install rclone.
If someone have a tip I ll appreciate it.
Thanx in advance.
Regards
TMS
Re: Curl, screen and Rclone
Post by TMS »
Please refer to this link to get the instructions:viewtopic.php?f=37&t=506
mutchix
Post by mutchix »
Did you, or someone else, manage to package a Rclone .Tpk working on TOS ?
I'm not too familiar with the packaging procedure, but i'll gladly try Rclone on my NAS !
is your nas an x64 version ?
I'll check on that
DiscoSi
Post by DiscoSi »
There is a wget version in TOS which may help you get packages over to the server.
/usr/bin/ter_wget
I've used it to get source tar files over for compilation without any issues.
DiscoSi
Cafsenra
Portugal
Post by Cafsenra »
Also there is a curl version: /usr/bin/ter_curl
DevOps Engineer. Software Developer on free time ;)
mutchix
Post by mutchix »
outkastm wrote: 21 Jan 2021, 00:47 is your nas an x64 version ?
I'll check on that
Sorry for the delay, and yes i have a X64 version ( F2-422).
The reason i'd like to try Rclone is because of it's --fast-list option, to have a complete cloud backup with the possibility to access to each file trough my B2 storage ( and not pay an awful lot for transactions only).
Thanks in advance if somebody can share the APK for me to test this, or if someone is already using rclone to B2 on a TNAS and has some tips !
If not i'll try the wget way, but this is my first NAS and i don't want to loose my backup accidentally :)
nygage
Post by nygage »
jhdscript wrote: 24 Nov 2020, 00:11 Hello all,
Thanx in advance.
Regards
Did you found screen packed?
scrren is available in ModBase1 3rd party package
viewtopic.php?f=37&t=1476
