[ Hawser ] Remote Docker agent for Dockhand - manage Docker hosts anywhere.
About: https://github.com/Finsys/hawser
Category:
Applicable models: x.64 series, ARMv8.2 series
Applicable TOS6: 6.0.420 or later versions
Applicable TOS7: 7.0.0375 or later versions
App download: https://tmnascommunity.eu/download/hawser
TOS6 & TOS7: click on Support & Help from app description inside the App Center
What Is Hawser?
Hawser is a companion daemon that runs on remote Docker hosts and exposes the local Docker Engine API to a central Dockhand instance. Instead of installing a full management web interface on every single server, you run Dockhand in one place and deploy Hawser on every remote node you want to control.
Once connected, the remote machine appears right inside Dockhand's Environments switcher—giving you full container lifecycle management, image pulls, volume/network controls, real-time log streaming, interactive terminal (exec) sessions, and Docker Compose stack deployments from a single glass pane.
