System: u12-500 plus,
- 16GB RAM
- 2* SATA SSD (Samsung 850 Pro) - System, Storage Pool 2 (RAID 1), Volume 2 (ext4)
- 2* NVMe (Samsung 990 Pro) - Storage Pool 3 (RAID 1), Volume 3 (BTRFS)
- 6* Seagate IronWolf Pro - Storage Pool 1 (TRAID+), Volume 1 (BTRFS)
System was initialised and newest TOS version installed (7.0.1422).
When I shut down the system it does not start the next time I power it on (kernel panic - not syncing: No working init found. Try passing intit= option to kernel. See Linux Documentation/admin-guide/init.rst for guidance).
Powering off and a new start results in the system coming up again.
As this happened the last three times I shut the system down, I guess it is a reproducible error.
Log center doesn't show any errors.
After the restart I can see in the console:
dmesg | grep -i error
[ 1.139411] RAS: Correctable Errors collector initialized.
[ 31.322661] EDAC igen6 MC1: HANDLING IBECC MEMORY ERROR
[ 31.322662] EDAC igen6 MC0: HANDLING IBECC MEMORY ERROR
[ 31.414073] proc_thermal_pci 0000:00:04.0: error: proc_thermal_add, will continue
[ 32.003155] i915 0000:00:02.0: Direct firmware load for i915/adlp_dmc.bin failed with error -2
dmesg | grep -i warning
[ 0.000000] x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
[ 32.042265] [668]: dev_vdisk: ***WARNING***: Unable to find /var/lib/scst/vdev_mode_pages (err -2), saved mode pages disabled. You should create this directory manually or reinstall SCST
Apps can be installed and seem to function, but it doesn't feel ok, when I have to start, power off and start again every time the system is shut down.
Any advices? Any details you would need for further analysis?
Best, Jens
system does not boot after regular shutdown and power off. Kernel panic.
Jump to
- TerraMaster News
- ↳ News & Announcements
- ↳ News and Announcements
- ↳ Update Notice
- ↳ Community Events
- ↳ New and Key Features in TOS 6
- TOS/TNAS
- ↳ FAQ & User Guides
- ↳ Initialization & Installation
- ↳ System Configuration
- ↳ File Service
- ↳ Networking
- ↳ Storage
- ↳ Backup & Restore
- ↳ Hardware
- ↳ Applications
- ↳ TOS Issues Report
- ↳ Initialization
- ↳ System Update
- ↳ Privileges
- ↳ File Services
- ↳ Network
- ↳ Storage
- ↳ System Resources
- ↳ Compatibility
- ↳ Hardware, Power and Accessories
- ↳ Security
- ↳ Mobile Apps and Desktop Clients
- ↳ Data Backup
- ↳ How to back up? Which one is right for me?
- ↳ TerraSync
- ↳ Centralized Backup
- ↳ Duple Backup
- ↳ CloudSync
- ↳ Snapshot
- ↳ TFSS
- ↳ USB Copy
- ↳ TFM Backup
- ↳ Rsync
- ↳ Time Machine
- ↳ Multimedia
- ↳ DLNA/Multimedia Services
- ↳ Multimedia Server
- ↳ Photos
- ↳ Plex Media Server
- ↳ Emby Media Server
- ↳ Jellyfin Media Server
- ↳ Virtualization
- ↳ Docker
- ↳ Virtual Machines
- ↳ Applications
- ↳ iSCSI Target
- ↳ Surveillance Manager
- ↳ VPN Server
- ↳ Download
- ↳ Web Server/PHP/MySQL/MariaDB
- ↳ Terra Search
- ↳ API-in-a-Box (Powered by GenAI Logic™)
- ↳ Others
- ↳ Feature Requests & Enhancement Proposals
- ↳ New Requests & Proposals
- ↳ Accepted
- ↳ Scheduled
- ↳ Released
- ↳ Discussion & Sharing
- ↳ Developer Discussion Room
- ↳ Community-Created Guides
- ↳ Lounge and Boast
- TDAS (TerraMaster DAS)
- ↳ Thunderbolt Series
- ↳ USB Series
- ↳ Issues Report
- ↳ USB Series
