cannot see plex outside my home
bradsplexflix
Post by bradsplexflix »
Hi, i run a plex server and i can no longer see it outside my home. I forwarded port 32400. i did some clean up with my discs the other day. i have 2 28tb drives and a 512gb nvme. i had apps all over the place so i decided to format my drives 1 at a time (move all data to 1 and format the other then vice versa). i installed plex on my nvme and now i cannot connect to plex outside of my home. please help.
Re: cannot see plex outside my home
Based on the information available, it's not yet clear where the problem lies. Port forwarding? The Plex service?
If you can successfully access Plex on your local network, you'll need to check your port forwarding and WAN/DDNS settings.
You might find this helpful:
https://www.noip.com/support/knowledgeb ... ip-version
https://www.noip.com/support/knowledgeb ... ding-guide
bradsplexflix
thank you for replying. i think it must be the tnas plex. i created a 2nd plex server on my local server and plex could be seen outside my home. i'm at a loss atm. at least i can add my music to my server so i can listen to music outside my house.
If you have more information about Plex on TNAS, please share it here—we may be able to offer some advice based on the details you provide.
Return to “Others”
