Thank you for your feedback and the additional details.
To pinpoint the exact cause, we'd like to confirm one key detail: during this upgrade, did you re-download or modify the docker-compose.yml in any way? (For example, adjusting the database section per Immich v3's VectorChord migration guide, or re-downloading the file from the official release.)
Here is the background:
- Immich's official standard upgrade process (
https://docs.immich.app/install/upgrading/) only requires running `docker compose pull && docker compose up -d` in your existing compose directory, and does NOT modify the compose file itself;
- However, if the docker-compose.yml was replaced or rewritten during the upgrade (the v3 VectorChord migration does require editing this file), that "delete old file, write new file" action would trigger Container Manager's project file-validity check, producing exactly the "Compose configuration file has been deleted" message;
- If you are certain the file was never touched, this points to an issue with the project record itself, and we will forward it to our test team for further reproduction and investigation.
If the first scenario applies, you can clear the error simply by re-associating the project with your existing file:
1. In Container Manager > Projects, remove the Immich project showing the error (important: do NOT select any option to delete containers or data when removing the project);
2. Create a new project by importing the current docker-compose.yml in your Immich directory, keeping the same project name as before;
3. The running Immich containers will be automatically recognized and adopted into the new project, and the error will disappear.
We look forward to your confirmation, and we'll continue to follow up based on your situation. Thank you for your patience and cooperation!
