MeTube Download
MeTube is a self-hosted web UI for yt-dlp, used to download videos and audio from YouTube and many other sites without opening a terminal. Paste a URL in the browser, choose video quality or audio-only format, and MeTube queues the job, showing real-time progress. It can fetch single videos, whole playlists, channels, subtitles, thumbnails, and metadata; audio extraction and format conversion are handled with ffmpeg.
Advanced options include custom output filename templates, separate video/audio folders, concurrent or sequential download modes, playlist item limits, and channel subscriptions that periodically check for new uploads and auto-queue them. It also accepts raw yt-dlp options via environment variables, so you can control codecs, subtitles, rate limits, cookies, and postprocessing.
Moechz/MeTube Download
Re: Moechz/MeTube Download
Did you set r/w permission /Volume1/Media for user metube? Do this in TOS 7 control panel > privileges > shared folder > permission > application permission.
but youtube not downloading
Message: [youtube] No supported JavaScript runtime could be found. Only deno is enabled by default; to use another runtime add --js-runtimes RUNTIME[:PATH] to your command/config. YouTube extraction without a JS runtime has been deprecated, and some formats may be missing. See https://github.com/yt-dlp/yt-dlp/wiki/EJS for details on installing one [youtube] This video is not available Only images are available for download. use --list-formats to see them Requested format is not available ERROR: [youtube] ZSW-zsPfybE: No video formats found!
