Shortcut links to open another tab in file manager
rfbjr
Post by rfbjr »
It would be nice if file manager is open already and you click on another shortcut, it opens in a new tab. Presently it just reuses the first tab, if that makes any sense.
F4-424 Pro (x2) and F4-425 Plus at 7.0.1536
F6-424 Plus at 7.1ß
D4-320 & D4-SSD
Re: Shortcut links to open another tab in file manager
Thank you for your suggestion. I will forward this request to the product team for evaluation.
rfbjr
Post by rfbjr »
Taking this a step further, yes you can now open another tab. Can you add the ability to do a side by side view of the two tabs or "pop out" the other tab.
Apologies if request already by me or someone else? :)
F6-424 Plus at 7.1ß
D4-320 & D4-SSD
EriChan
Post by EriChan »
rfbjr wrote: ↑16 Nov 2026, 02:13
Thank you for the follow-up feedback.
First, as a quick update on your earlier request: having shortcuts open in a new tab instead of reusing the existing tab is planned for TOS 7.1.
As for taking it a step further—adding a side-by-side (split) view or the ability to pop out a tab into a separate window is a great idea for making file comparisons and cross-folder transfers much smoother in File Manager. I have noted this follow-up suggestion along with the earlier context and will forward it to our product team for further evaluation.
We truly appreciate you sharing your thoughts to help us keep improving TOS!
