Emby no longer works under 4.2.06
Ryzen
Post by Ryzen »
Since I switched to 4.2.06 Emby is no longer seen on my network. It starts in TOS, I can access its web interface but no device sees it anymore
I have checked the parameters and everything is active, notably the DLNA (UPNP)
Before the update everything was working
F2-210
4.2.06
Ryzen
Re: Emby no longer works under 4.2.06
Post by Ryzen »
And install package manualy does't work to
F2-210
4.2.06
Ryzen
Post by Ryzen »
Ho it's ok works again don't know why
F2-210
4.2.06
Thanks for the feedback.
Keep us noted if it happens again.
Ryzen
Post by Ryzen »
Yes it's happens again.
Emby is started well and I can access the settings but unable for network devices to see it and play media content
F2-210
4.2.06
Have you cleaned up the browser cache since you upgraded to TOS4.2.06? You can try it.
Ryzen
Post by Ryzen »
Yes i do But I think there is no connection. My tv (SmartTv), my pc, my console, my tv box no longer see the emby server since TOS Update 4.2.06. Thank you
F2-210
4.2.06
We will test and confirm it here first, and get back to you later.
You can also send an email to our support team support(at)terra-master.com, and we can arrange a remotely check for you.
Return to “Plex Media Server”
