[Help] Low file copying speed over the network
- protogonist
Hello to all.Initially, the NAS was connected to the mesh point via a cable, and the PC was also connected to the same point via a cable. The file copying speed from the PC to the NAS was similar to that of an internal hard drive (120–150 MB/s). Then I moved the NAS to another room, and now it is connected via a cable to another mesh point. Now the system looks like this: room 1, with a PC in it, connected via a cable to the mesh point. This mesh point is connected via WIFI to a second identical point, to which the NAS is connected via a cable, and to which the internet input cable is attached. The file copying speed does not exceed 300–600 kb/s. TNAS is installed latest, factory reset was performed. The network adapter in the PC was not changed; Windows was reinstalled. What should be checked to restore the speed? Thank you. Mesh system - Deco BE65 Pro, NAS - TMaster 425.
Re: [Help] Low file copying speed over the network
Since your speed was normal (120–150 MB/s) when both devices were wired to the same node, the hardware and drive performance are healthy. A drop to 300–600 KB/s strongly indicates a network-level routing issue or a severe bottleneck in the wireless mesh link.
Here are the key points to check to identify and resolve the issue:
1. Verify Connection Method
- Local IP vs. Cloud ID: Ensure you are accessing the NAS via its local LAN IP address (e.g., \\192.168.2.xxx in Windows Explorer or browser).
- If you connect using DDNS or remote quick-connect tool, changing network points might cause the traffic to route out to the internet through an external relay server rather than staying local.
When moving the cables, a bent pin or poor contact can cause the link to downgrade or suffer packet loss:
- On the NAS: Go to TOS > Control Panel > Network > Interface, and verify the physical connection status shows 1000 Mbps (or 2.5 Gbps) Full Duplex.
- On the PC: Open Windows Settings > Network & Internet > Ethernet (or Network Adapter Properties) to confirm the link speed is negotiated at 1000/1000 Mbps (or higher).
- Backhaul Signal Strength: Open the TP-Link Deco App and check the signal health between Node A and Node B. If the two nodes are too far apart or separated by thick walls, the wireless backhaul link may degrade significantly.
- Device Isolation / Guest Network: Make sure neither the PC nor the NAS was accidentally assigned to an IoT / Guest Network or has Client Isolation enabled in the router settings.
- QoS / Security Inspection: Temporarily disable QoS or HomeShield Antivirus / Intrusion Prevention features in the Deco app to test if deep packet inspection is throttling local inter-node traffic.
To isolate whether the bottleneck is pure network throughput or SMB file transfer:
- Run an iperf3 throughput test between your PC and the NAS. If iperf3 also reports speeds in the KB/s range, the issue is purely the wireless link/routing between the two Deco nodes.
