Upgrade to 4.2.06 to use WOL but doesn't seem to work for me. Works well on my old netgear
Has anyone tested ?
WOL doesn't seem to work for me
Re: WOL doesn't seem to work for me
Thanks for the report. We will test again and get back to you later.
How it doesn't work? which WOL client you use? what massage you got from there?
My internet box is able to send magic packets over the LAN. Works on my pc, my other NAS (NetGear).
I don't have a log, just the magic packets have been sent.
F2-210
4.2.06
4.2.06
To use the WOL feature,
1. Enable the WOL from the TOS control panel;
2. If you are using Windows OS, you can download a WakeMeOnlan client https://www.nirsoft.net/utils/wake_on_l ... nloadLinks
3. Follow the instruction of WakeMeOnlan client to wake up your TNAS.
Notes:
1. For x.64 TNAS, you need to enable the WOL feature from BIOS before you can it;
2. Only LAN 1 can act as a WOL port;
3. Your TNAS device needs to be shut down properly.
Notes:
Yes I have activated the option in TOS before doing the test. I don't see how it makes a difference to try an application on Windows if my router has a WOL client. It makes it easier to reach all the devices on its LAN and I know it works because I have tested it on other devices before. I still tested your software and it doesn't work any better. In any case on an F2-210
F2-210
4.2.06
4.2.06
We will verify the issue at our side again, and keep you updated.
