[Help] TOS 7.0.0804 - NTFS USB drives fail to mount - StorageManager uses invalid gid=allusers
DebuggaNB
Post by DebuggaNB »
Issue summary
After upgrading my TNAS to TOS 7, external NTFS disks connected over USB are detected correctly by Storage Manager, but remain Unmounted.
I tracked the problem down to the ntfs-3g command being generated by TOS StorageManager.
StorageManager is passing:
gid=allusers
to ntfs-3g. ntfs-3g requires the gid option to contain a numeric GID, so the mount fails.
I was able to reproduce the failure manually and then successfully mount the same filesystem by changing only this option from
gid=allusers
to the numeric GID for the allusers group.
System / environment
TOS: 7.0.0804
Architecture: x86_64
Kernel: 5.15.59
External enclosure: Sabrent Dual SATA Bridge (USB)
Two GPT/NTFS disks are installed in the enclosure:
  • 12 TB - label: PlexOffline
  • 4 TB - label: 4tbEvac
ntfs-3g version:
ntfs-3g 2021.8.22 integrated FUSE 28
USB detection works correctly
Both disks and their NTFS partitions are detected:
NAME    SIZE FSTYPE LABEL       UUID
sdf    10.9T
├─sdf1   16M
└─sdf2 10.9T ntfs   PlexOffline <UUID-PlexOffline>
sdg     3.6T
├─sdg1   16M
└─sdg2  3.6T ntfs   4tbEvac     <UUID-4tbEvac>
TOS also remembers both volumes in:
/etc/tos/config/usb_mount_map.json
However, their last_seen_path remains empty and neither filesystem is mounted.
StorageManager mount attempt
The StorageManager journal shows TOS attempting both RW and RO mounts:
TNAS-NAS storagemanager: DEBUG /usr/bin/ntfs-3g -o rw,noatime,big_writes,async,iocharset=utf8,gid=allusers,dmask=007 /dev/sdf2 /Volume1/@usb/usb_PlexOffline
TNAS-NAS storagemanager: DEBUG /usr/bin/ntfs-3g -o ro,noatime,async,iocharset=utf8,gid=allusers,dmask=007 /dev/sdf2 /Volume1/@usb/usb_PlexOffline
TNAS-NAS storagemanager: DEBUG /usr/bin/ntfs-3g -o rw,noatime,big_writes,async,iocharset=utf8,gid=allusers,dmask=007 /dev/sdg2 /Volume1/@usb/usb_4tbEvac
TNAS-NAS storagemanager: DEBUG /usr/bin/ntfs-3g -o ro,noatime,async,iocharset=utf8,gid=allusers,dmask=007 /dev/sdg2 /Volume1/@usb/usb_4tbEvac
Neither attempt succeeds.
Reproducing the error manually
I created a temporary mountpoint and ran the same RO command being generated by StorageManager:
/usr/bin/ntfs-3g -o ro,noatime,async,iocharset=utf8,gid=allusers,dmask=007 /dev/sdf2 /Volume1/@usb/test_PlexOffline
ntfs-3g immediately returns:
'gid' option needs a decimal value
This appears to identify the reason both StorageManager mount attempts fail.
allusers group
On the TNAS:
$ getent group allusers
allusers:x:997:guest,admin,SysAdminTron
Therefore the numeric GID on this system is:
Same mount succeeds with numeric GID
I repeated the same mount, changing only
gid=allusers
to
gid=997
/usr/bin/ntfs-3g -o ro,noatime,async,iocharset=utf8,gid=997,dmask=007 /dev/sdf2 /Volume1/@usb/test_PlexOffline
The command completed successfully.
findmnt then confirmed:
TARGET                          SOURCE     FSTYPE   OPTIONS
/Volume1/@usb/test_PlexOffline  /dev/sdf2  fuseblk  ro,noatime,...
So:
gid=allusers  -> mount fails
gid=997       -> mount succeeds
NTFS filesystem checks
I also checked both NTFS filesystems with ntfsfix in no-action mode before testing.
12 TB disk:
$ ntfsfix -n /dev/sdf2
Mounting volume... OK
Processing of $MFT and $MFTMirr completed successfully.
Checking the alternate boot sector... OK
NTFS volume version is 3.1.
NTFS partition /dev/sdf2 was processed successfully.
4 TB disk:
$ ntfsfix -n /dev/sdg2
NTFS partition /dev/sdg2 was processed successfully.
The issue therefore does not appear to be filesystem corruption or an NTFS dirty-state problem.
Native USB detection/retry also reproduces the problem
I manually retriggered the native TOS USB insert handler:
/etc/udev/scripts/usb_operate insert sdf
/etc/udev/scripts/usb_operate insert sdg
StorageManager accepted both insert events successfully, but again generated the same ntfs-3g commands containing:
gid=allusers
and both volumes remained unmounted.
Suspected cause
It appears StorageManager is passing the TOS group name:
gid=allusers
directly to ntfs-3g.
ntfs-3g expects this option to contain a decimal/numeric GID.
StorageManager presumably needs to resolve the allusers group through the system group database before constructing the mount command.
For example, on this TNAS:
allusers -> GID 997
and using:
gid=997
successfully mounts the same filesystem.
Expected behavior
When an NTFS USB disk is detected, StorageManager should automatically mount it under:
/Volume1/@usb/usb_<label>
using the numeric GID corresponding to the TOS allusers group.
Actual behavior
The USB disks are detected and displayed by TOS, but remain Unmounted.
StorageManager attempts RW and then RO mounting. Both commands contain
gid=allusers
, which ntfs-3g rejects because the gid is not numeric.
Current workaround
As a temporary workaround I created a TOS startup task that discovers the USB filesystems by UUID and mounts them using the same ntfs-3g options with the numeric allusers GID.
This successfully mounts both drives read/write.
I would prefer to use the normal TOS USB automount functionality, so hopefully StorageManager can be corrected to resolve the allusers group to its numeric GID before calling ntfs-3g.
Please let me know if additional logs or testing would be useful.
Re: [Help] TOS 7.0.0804 - NTFS USB drives fail to mount - StorageManager uses invalid gid=allusers
Hi, I'm sorry you encountered this issue, and thank you very much for sharing your findings. I've forwarded them to the project team, and I hope they'll find them helpful.
You may want to consider downloading this new version of the Storage Manager app and manually uploading and installing it to resolve the issue.
https://download3.terra-master.com/Apps ... _amd64.deb
