[Help] Logrotate gives errors, is this a problem ?
petrose
Denmark
Post by petrose »
I am on newest TOS7 (7.0.0804) and getting these errors, using grep 'rotate' /var/log/syslog | tail:
Jul 29 12:00:00 SonjaNAS logrotate[34732]: error: collectd:1 duplicate log entry for /var/log/VMs/collectd.log
Jul 29 12:00:00 SonjaNAS logrotate[34732]: error: found error in file collectd, skipping
Jul 29 12:00:00 SonjaNAS logrotate[34732]: error: noVNC:1 duplicate log entry for /var/log/noVNC/vnc.log
Jul 29 12:00:00 SonjaNAS logrotate[34732]: error: found error in file noVNC, skipping
Jul 29 12:00:00 SonjaNAS systemd[1]: logrotate.service: Deactivated successfully.
I wonder if you already know this behaviour ?
BR Peter
BR PetRose
My TNAS: F8 SSD Plus, now with TOS7 Final version along with 1+3x2 TB SSD sticks, formatted as BTRFS and using TRAID
Re: [Help] Logrotate gives errors, is this a problem ?
Could you let me know what action caused this log to appear?
rfbjr
Post by rfbjr »
Here is how I see it. When the NAS is booted (in my case 01:35 each day) and this example VMs collectd.log
The log is created.
But the way the logrotate entry is coded, it doesn't expect collectd.log to exist.
The logrotate.service runs every hour and generates the same error.
F6-424 & F4-425 Plus at 7.0.1163
F4-424 Pro (x2) also at 7.0.1163
D4-320
Return to “System Resources”
