Running on latest TOS7 (7.0.0804) I still getting errors in /var/log/VMs/collectd.log file: df plugin: Failed to glob vdisk files
Below I have a snippet of the first part where it starts:
It persists, and is repeated every 2 seconds !
I reckon there might be some degradation because of this.
Is this fixable, by myself or from the Support side of yours ?
BR Peter
BR PetRose
My TNAS: F8 SSD Plus, now with TOS7 Final version along with 1+3x2 TB SSD sticks, formatted as BTRFS and using TRAID
This message is merely a warning and has no impact on system performance or degradation.
Cause:
This happens due to how logrotate.conf handles pre-existing log files, which was not anticipated and causes the duplicate/repeating log entries.
Solution:
You can simply delete /var/log/VMs/collectd.log (or remove the existing log files in that directory). Once deleted, logrotate will handle the files normally and the repeating log messages will stop.
Cause:
Solution:
Done, Well I did the delete on the first F4-424 Pro before the hourly logrotate run. Ran clean as to be expected. Just deleted the files on the other two devices, so I'll check all three in about 30min.
Thank you
F4-424 Pro (x2) at 7.0.1298
