[Help] Should I Update F2-424 BIOS to MADN0101.V08
beagle062
Post by beagle062 »
My TNAS is F2-424 with TOS version 7.0.0791
My F2-424 has BIOS MADN0101.V05 installed. The newest F2-424 BIOS is MADN0101.V08
Questions
1 - Should I upgrade to the new newest F2-424 BIOS MADN0101.V08
2 - Is it worth the risk to update to new BIOS if TNAS is running fine on old BIOS MADN0101.V05?
3 - How do I upgrade to new F2-424 BIOS is MADN0101.V08
4 - Where can I read the change log for all BIOS version
Re: [Help] Should I Update F2-424 BIOS to MADN0101.V08
If it ain't broke ..... No significant changes in the bios apparently.
Frustrated Beta Tester!!!
The F2-424 with BIOS version MADN0101.V05 does not require any additional adjustments and can be updated and run normally under TOS 7.
For more details, please refer to:
viewtopic.php?t=10181
beagle062
Post by beagle062 »
Thanks Gremlin & TMzethar.
I will follow your best advice.
If it ain't broke, don't fix. Let it be.
I will keep my F2-424 running MADN0101.V05 BIOS
