Applications filter
yerc1
Applications filter
Post by yerc1 »
I need to know which apps in the Applications list are made by Terramaster because (1) if there are alternative apps for the same task, I would trust the app by Terramaster ;) ; and (2) we could gauge how interested third party developers are in making apps for Terramaster products.
Issue:
It's a very tedious task to get to see the apps developed by Terramaster.
At the moment, one needs to check every application to find out which one was from Terramaster. If the Applications list grows (and I'm all for it), it would be impossible to do this.
Filters in Applications currently are: All, Backup, Business, Tools, Multimedia, Security, Utilities. See screenshot.
Request:
Please add "By Terramaster" filter in Applications.
F2-221
Re: Applications filter
Your request will be reported to the related dept, and they will consider it. Thank you.
Return to “Others”
