Hi everyone,
I have a TerraMaster F6-424 Max with the stock 8GB DDR5 SO-DIMM module (TerraMaster A-SRAMD5-8G, 4800MHz) and I'd like to add a second 8GB module to enable dual-channel, without replacing the existing one.
I'm considering the Crucial CT8G48C40S5 (DDR5-4800 SO-DIMM, CL40, non-ECC) as the second module, since it matches the same type, frequency, and timing as the stock module (and the terramaster A-SRAMD5-8g is out of stock everywhere ).
Has anyone here successfully run a Crucial module alongside the original TerraMaster-branded module on the F6-424 Max (or a similar DDR5 model)? I've seen reports on other TerraMaster models of boot issues when mixing brands, so I wanted to check if anyone has real-world experience with this specific combination before I buy.
Thanks in advance for any feedback!
F6-424 Max - Adding Crucial CT8G48C40S5 alongside stock TerraMaster module?
Re: F6-424 Max - Adding Crucial CT8G48C40S5 alongside stock TerraMaster module?
I have never had problems with Crucial memory on Tnas, but I never tried DDR5. If you can get it I would say try it. If it's a reasonable price it will be an appreciating asset, for a while at least.
For those interested, since the terramaster ram are out stock everywhere, this module runs in dual channel with the stock RAM.
WARNING -- The above is only a rough guideline.
For best results, please be sure you know the
precision of your system timer.
Function Best Rate MB/s Avg time Min time Max time
Copy: 52369.5 0.013335 0.012221 0.014612
Scale: 38049.5 0.017537 0.016820 0.017924
Add: 42845.9 0.023999 0.022406 0.025171
Triad: 43074.6 0.023967 0.022287 0.024708
Solution Validates: avg error less than 1.000000e-13 on all three arrays
Admin@F6-424:/#
Memory Device
Array Handle: 0x0027
Error Information Handle: Not Provided
Total Width: 64 bits
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: Controller0-ChannelA-DIMM0
Bank Locator: BANK 0
Type: DDR5
Type Detail: Synchronous
Speed: 4800 MT/s
Manufacturer: KingboMars Technology Co Ltd
Serial Number:
Asset Tag: 9876543210
Part Number: A-SRAMD5-8G-JB4800M
Rank: 1
Configured Memory Speed: 4800 MT/s
Minimum Voltage: 1.1 V
Maximum Voltage: 1.1 V
Configured Voltage: 1.1 V
Memory Technology: DRAM
Memory Operating Mode Capability: Volatile memory
Firmware Version: Not Specified
Module Manufacturer ID: Bank 8, Hex 0x68
Module Product ID: Unknown
Memory Subsystem Controller Manufacturer ID: Unknown
Memory Subsystem Controller Product ID: Unknown
Non-Volatile Size: None
Volatile Size: 8 GB
Cache Size: None
Logical Size: None
Handle 0x0029, DMI type 17, 92 bytes
Memory Device
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Locator: Controller1-ChannelA-DIMM0
Type: DDR5
Speed: 4800 MT/s
Manufacturer: Crucial Technology
Serial Number:
Part Number: CT8G48C40S5.M4A1
Rank: 1
Module Manufacturer ID: Bank 6, Hex 0x9B
Volatile Size: 8 GB
Cache Size: None
Logical Size: None
Admin@F6-424:/#
Admin@F6-424:/#
Memory Device
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Type: DDR5
Speed: 4800 MT/s
Serial Number:
Rank: 1
Volatile Size: 8 GB
Cache Size: None
Logical Size: None
Memory Device
Data Width: 64 bits
Form Factor: SODIMM
Set: None
Type: DDR5
Speed: 4800 MT/s
Serial Number:
Rank: 1
Volatile Size: 8 GB
Cache Size: None
Logical Size: None
Admin@F6-424:/#
