[Help] Errant LAN1 has re-appeared! (F2-425Plus)
See also: viewtopic.php?p=57763#p57763
Since the install of Tos7.0.0777 I see this issue has reappeared. I don't know if this is specific to installing .0777 or if it was earlier and I didn't notice. I know I can "fix" this, but I have no wish to be re-creating a network bond every time I update the os. How can this be fixed permanently?
ps: I don't see this on my -424 model with similar bonding arrangements.
Re: [Help] Errant LAN1 has re-appeared! (F2-425Plus)
We have logged the issue you reported. Our team will verify and investigate it. Thank you for bringing it to our attention. We will post updates here as we make progress.
Thank you. I like a mystery as much as anyone, but sometimes .......
new release .0780 appears to have "diminished" the issue :)
The errant LAN 1 entry is not appearing in network > Interface any longer.
However:
The external (WAN) network only shows "orange" unless IPv6 is set to 'Disable' (from 'Auto')
I cannot delete the errant Lan1 entry from TnasPC "Access History" - Update: Deleted after restart of TnasPC and refresh.
WOL does not work from TnasPC (It does work from 3rd party app.) (Bonded ports)
{Only F2-425+ tested}
Return to “Network”
