OpenVPN LAN access setting confusion
An application set your TNAS as a VPN server
Solbot
Australia
Post by Solbot »
Under OpenVPN there is an option that says "Allow clients to access the local area network where the server is located" suggesting that you should tick it for LAN access. This actually disables LAN access.
It should probably say "Disable client LAN access" or similar.
VPN Server 2.0.055 TOS 7.0.0765
EriChan
Re: OpenVPN LAN access setting confusion
Post by EriChan »
Thank you for your feedback. We will continue to monitor the situation and attempt to replicate the issue you mentioned.
Return to “VPN Server”
