TOS7 OpenClaw will not install
ShowsOn
Australia
Post by ShowsOn »
Running TOS 7 build 765 on my F4-425 Plus I purchased yesterday
Pretty straight forward issue. I go to Software Center and try to install OpenClaw Beta and it seems to download and try to install but then says that the installation failed. I have looked through the system logs but it doesn't say anything about why the intallation failed.
Any help to get this installed would be appreciated as I may be able to use it to schedule Tailscale and Jellyfin to load at start up as set out in this other thread:
viewtopic.php?t=10215
I have tried turning Deceloper mode on. This did not work.
Note. All my other computers are Windows or Mac. I am not familiar with Linux.
Re: TOS7 OpenClaw will not install
We haven't been able to reproduce the issue you described. To better understand what's happening, we recommend generating a system report and sending it to our support team for analysis.
You can find this option at: TOS Desktop > Support and Help > Report Issues.
ShowsOn
Australia
Post by ShowsOn »
TMzethar wrote: ↑05 Jul 2026, 21:51 We haven't been able to reproduce the issue you described. To better understand what's happening, we recommend generating a system report and sending it to our support team for analysis.
Thank you. I have emailed my system report.
Simon
EnchongG
Philippines
Post by EnchongG »
I Have the same problem, what i did is i download manually and installed it manually with the image below
A new DEB file of OpenClaw to manually install and this worked.
flukegrind
Post by flukegrind »
I totally get the frustration with TOS7 installation issues! I faced similar hurdles when setting up my TerraMaster. One tip that helped me was checking the firmware version—sometimes compatibility can be tricky.
ShowsOn wrote: ↑05 Jul 2026, 16:43
Please update your TOS to 7.0.1130 or later version.
Return to “Others”
