on my MacBook Pro 16, I Plugged the TDAS, and on the TDAS I plugged a 4K screen via a thunderbolt / usb-c cable, and a Thunderbolt Display from apple via a DisplayPort cable.
It doesn't work for the apple thunderbolt display, does any constraint on this device ?
by the way the screen works perfectly directly connected to the Mac (via an adapter).
apple Thunderbolt Display and TDAS
Re: apple Thunderbolt Display and TDAS
You need to make sure your monitor supports thunderbolt 3, and you are using a certified thunderbolt 3 cable instead of USB C cable.
the thunderbolt display os connected to the display port of the Terramaster not the thunderbolt port....
this is a display port screen from apple, the screen works from the thunderbolt port with an adapter, so I believe it is possible to connected to the display port ?
