[Help] TOS 7 upgrade and SPC user homes issue
rvescovi
Italy
Post by rvescovi »
my configuration is Volume1 (singled SSD for OS) and Volume2 (RAID for data).
On T0S6 I was able to install the OS on SSD and the users on RAID.
After I (finally) upgraded to TOS7 .750 it was necessary to recreate all users configuration which I did it, without loosing any data all users linked correctly to their previous homes on /Volume2/homes. So in Volume2/homes I have ./user1, ./user2, ...
Now I decided as recommended to enable SPC and after boot, my admin users will be linked to /Volume1/home (not homes anymore and neither Volume2) but I loose any document relations stored in the /Volume2/homes/ .
So PHOTO, TERRASYNC, .. not working, and MEDIA indexing still show as private directory /homes/riccardo/Photos, which differs from PHOTO which now includes /home/riccardo/Photos.
Additionally, all other users are not linked anymore to their data and If I create a new for test it will be under /Volume1/home. (not homes).
It seems that SPC disable the "homes" approach. Is it possible that during the SPC enablement, went missing some mount configurations?
Is there a way to restore the previous configuration?
rvescovi
Italy
Re: [Help] TOS 7 upgrade and SPC user homes issue
Post by rvescovi »
Hi, to partially solve the issue I did:
mount --bind /Volume2/homes /home
but I didn't make any permanent changes awaiting your feedback.
Thanks.
EriChan
Post by EriChan »
To better assist you in confirming whether there are any abnormalities in the TOS system, please send the complete log to our technical support email at [email protected] via email, and attach the forum link and your forum ID as well.
SignorAutoma
Italy
Post by SignorAutoma »
Hi @rvescovi,
I'm experiencing the same issue on a fresh TOS 7 installation. Is your volume binding solution working correctly with all the related features, such as Photos, TerraSync, and the other user-specific services?
Thanks in advance!
rvescovi
Italy
Post by rvescovi »
Yes, it seems working on PHOTO but you need per each user add again its local folder for indexing (at least in my case disappeared) and then it works as in the past.
This is only a workaround due for TERRASYNC server after my BIND I can reach again from the TERRAMASTER UI the documents but I'm having an issue on PC client APP which cannot find the /home/Terrasync directory. (it doesn't show the username in between the /home and /Terrasync)
To investigate more the issue I went also to the TERRAMASTER TOS 7 online demo to understand more on the mount. This demo hasn't the SPC active, and if I launch this command:
mount | grep home
I obtain this result: /dev/mapper/vg0-lv0 on /home type btrfs (rw,noatime,tmacl,space_cache=v2,subvolid=258,subvol=/@/homes)
rather on my NAS after the mount command I obtain this "subvol/@", it seems I need to mount differently, but it's unclear to me how to. I was waiting a newest release.
We apologize for the difficulties you have encountered.
With regard to the redirection of the homes directory to Volume1 following the enabling of SPC, we will conduct further verification. If you are currently using an older version of TOS 7, we recommend upgrading to the latest release before retesting.
Regarding the inability to designate the target volume for the homes directory, we are actively investigating this matter and are working on potential optimizations and a solution.
TerraTom
Australia
Post by TerraTom »
What would happen if you deleted the Volume with the /homes directory? Does TOS7 even allow it? If TOS7 recreates it on another volume then this might be a way to work around the issue but only if you can move everything else off Volume1 first.
I'm in the same situation. I was in the process of reconfiguring my main storage pool but now I'm stuck waiting for a fix.
EriChan
Post by EriChan »
TerraTom wrote: 21 Aug 2026, 09:01
We strongly advise against deleting the storage volume. Doing so will erase data and can easily cause system service errors and configuration issues.
Our product team is currently evaluating and optimizing a solution to allow customizing the target volume for user home directories, which will be introduced in a future update. Please stay tuned!
TerraTom
Australia
Post by TerraTom »
Thanks for the update. Also, just being able to move the Volume to another storage pool would solve the issue for me.
Return to “Privileges”
