[Discussion] File location of virtual machines used by VMs application
polen
Post by polen »
I'm trying to find the file location for the virtual machines used by the VMs application.
I see the VMs app in @apps, but where are the files for each virtual machine?
Thanks,
Hardware: F6-424 Max, 24GB RAM, 3 x 12TB WD Red Plus TRAID, 2 x NVMe 2TB TRAID, 2 x 500GB SD Ultra 3D RAID1 Quick Cache, 1 x 18TB WD USB3 Backup
Operating System: TOS 7.0.0791
Applications: Plex, VMs, Docker, USB Copy
MikeZhang
Re: [Discussion] File location of virtual machines used by VMs application
Post by MikeZhang »
polen wrote: 24 Jun 2026, 04:06
You may enter
ls -al /Volume1/
'@Repository' / is the storage pool
'@iSCSI' / is the virtual disk
'@GuestImage' / is the image
polen
Post by polen »
Mike, Thanks!
The reason I ask is I want to backup the virtual machines and setting. For VBox I just pointed USBCopy at my virtual machine share. What is the best practice to backup virtual machines and setting for the VMs application?
Thanks,
MikeZhang
Post by MikeZhang »
polen wrote: 26 Jun 2026, 01:57
To back up your virtual machines, it's recommended to try our Centralized Backup app
polen
Post by polen »
Currently Centralized Backup app only backs up VMware and Hyper-V. Are you saying that a future version will backup VMs virtual machines?
EriChan
Post by EriChan »
polen wrote: 26 Jun 2026, 23:10
Yes, the product department is currently evaluating this feature. In the meantime, it is recommended that you back up your VMs by exporting them to a shared folder.
Return to “Virtual Machines”
