Hi
I'm a newbie and a bit confused. When I open File Manager in TOS 6 my WIndows 11 PC (using Chrome browser) tells me that the connection isn't secure and https is not available.
Should I be concerned? Have I missed a step when setting up the NAS?
TIA
Peter
[Help] File Manager [SOLVED]
Re: [Help] File Manager [SOLVED]
This is normal. The "insecure" message indicates the browser detects the access address as unencrypted. It's normal for this to happen when accessing via IP address on a local network. Our certificate is for the tnas.online access address; therefore, it will display correctly when accessing remotely via tnas.online.
- PeterRobertson
Thanks Mike. Very helpful and reassuring
Adding an encryption certificate for local access is possible, but you will need to obtain an SSL certificate for your URL yourself, the prerequisite is that you need to bind a domain name to your NAS.. Because each user's environment is unique, we cannot do this on your behalf; it must be handled by you.
