Activation extension WebServer
Using Web Server, PHP, MySQL, MariaDB.
moussetik
Post by moussetik »
Sorry for my bad English, I'm a good French ...
I am trying to activate several extensions (in this case session and pdo mysql) of the web server, launched itself via the application provided in the TOS Store. I am not a pro in PHP configuration, but on other OS: I can do these operations perfectly.
I have done several searches. Obviously I am not the only one affected, but no one gives the procedure. So if you could write it here, future people like me wouldn't be looking for hours.
Here are the results of my research:
- viewtopic.php?f=32&t=665&p=4258&hilit=mysql#p4258
This person installed Wordpress manually with the store's web server, but Wordpress cannot find the PDO extension.
- https://forum.phpfrance.com/gestion-de- ... 80741.html
This user wants to use php sessions for his website but the extension is not activated either. I tested the manipulations proposed in this link, but as for the other user, impossible to activate them.
When I do the command "php -m" on a putty session as root, I get the list of active extensions (like on the first link). On the other hand, as I read in the second link, I imagine that this command is carried out on the TOS server itself, and not "WebServer" of the TOS store.
Could you help me by telling me how to activate the Web Server extensions that you make available to me in your store?
Here are the characteristics of my NAS:
- F4-210
- TOS 4.1.32-2008031214
Regards,
Franck
Re: Activation extension WebServer
We are going to release a new update for the Web Server in near future, with that you will be able to configure different php version for your web server.
moussetik
Post by moussetik »
Fantastic !
Do you have any thoughts on when this update will take place?
I really need it to work ...
Do you have any info on how to do the manipulation on my command line side in the meantime?
Or, could you confirm for me that with Docker I would be able to install a version of php that I can configure myself from the command line?
While waiting for your response, I still continue to search. I have access to the php configuration indicated in phpinfo () and putty, but the extensions seem to be active ...
Thank you for your reactivity!
I can't tell when exactly, but soon.
and sorry i can't provide you with information about the command line, as soon as I have, I will let you know.
tranqui69
Post by tranqui69 »
4 years later... Still waiting.
Return to “Web Server/PHP/MySQL/MariaDB”
