[Discussion] Storagemanger not displaying descriptions
rfbjr
Post by rfbjr »
On the mobile app (3.5.064), storage manager, it doesn’t display description for volumes and storage pools.
F4-424 Pro (x2) at 7.0.1298
Felix
Re: [Discussion] Storagemanger not displaying descriptions
Post by Felix »
In the app, the description of a volume and storage pool will be displayed in the description field of the corresponding volume and storage pool in the secondary menu.
rfbjr
Post by rfbjr »
Yes I saw that, but the first screen isn't really tight for space. :)
EriChan
Post by EriChan »
rfbjr wrote: ↑06 May 2026, 18:55
The current version was designed to keep the page clean and highlight core data. As you noted, however, displaying descriptions can indeed improve operational convenience when screen space permits.
I will relay this specific suggestion—adding description previews to the first-screen list items—to our mobile product team. We will evaluate the possibility of optimizing the UI layout in future releases to better balance visual aesthetics and practical functionality.
Thanks for your invaluable feedback on enhancing the user experience!
rfbjr
Post by rfbjr »
Just for reference:
The first Volume is the HDD's on the F6-424, 2nd Volume is the D4-320 and the 3rd is the SSD.
At a quick glance it very easy to forget which is which, with the first two volumes, give the total storage isn't that far apart.
