Does the system disk size allocation change if it is (for example) on a M.2 SSD 1TB or 2TB or even 4TB?
So aside from the storage pool would be larger, does the size of the M.2 matter for the size of the system partition allocation?
[Discussion] System disk on M.2 SSD [SOLVED]
F4-424 Pro (x2) and F6-424 at 7.0.1536
F4-425 Plus at 7.0.1422
D4-320 & D4-SSD
D4-320 & D4-SSD
Re: [Discussion] System disk on M.2 SSD
You're right. Our system partition size is fixed. The hard drive capacity only affects the data partition, which is the size of the storage pool partition you create.
Thank you, I thought so but wanted to make sure.
D4-320 & D4-SSD
D4-320 & D4-SSD
