[Discussion] Rsync with and without SSH  [SOLVED]
rfbjr
Post by rfbjr »
If I run an rsync task w/o SSH, the number of files successfully backed up is constantly updated.
Shot above is after the job finished.
But if I used SSH, same server and same folder being copied, the number of files is not updated until the end.
Point is when no SSH, I do have some idea how far along the job is, with SSH, no clue.
F4-424 Pro (x2) and F6-424 at 7.0.1536
F4-425 Plus at 7.0.1422
D4-320 & D4-SSD
Felix
Re: [Discussion] Rsync with and without SSH
Post by Felix »
Because one method uses the rsync service (port 873) and the other uses the system SSH (port 9222), it is currently impossible to check the status using SSH. This issue has been submitted to our TOS product department for investigation. Please pay attention to future software update announcements.
rfbjr
Post by rfbjr »
Ok thanks for the update. For now, If I'm copying something and busy doing other things, I use SSH, when I'm in a hurry and want to see how far, I use the non-SSH method. Cheezy but works.
D4-320 & D4-SSD
Felix
Post by Felix »
rfbjr wrote: ↑27 Apr 2026, 18:32 Ok thanks for the update. For now, If I'm copying something and busy doing other things, I use SSH, when I'm in a hurry and want to see how far, I use the non-SSH method. Cheezy but works.
Thank you very much for your understanding and cooperation. At this stage, you can flexibly choose the most suitable mode based on your actual business scenario and transmission needs. Regarding the issue you raised, we have recorded it in detail and will incorporate it into our product optimization evaluation plan.
Return to “File Services”
