TOS 7 Beta Is Available for Testing
Re: TOS 7 Beta Is Available for Testing
I have attempted to install TOS7 3 times on my F5-221 NAS. Every time it states that the install was completed but the system never re-boots to complete the install. When I try and manually restart it, the NAS is bricked! I lose the bootloader and have to rebuild the NAS each time.
Any idea what the problem is? I have the right BIOS and TOS6 version as per your Page 1 of this thread.
TOS settings:TMEmily wrote: ↑19 Dec 2025, 14:45Hello, thank you for your detailed description. The Open vSwitch enable operation itself does not change the DHCP or manual configuration mode of the port. The most likely scenario currently is that during the enabling process, the DHCP client process of the first port (LAN 1) encountered an issue, causing it to fail to automatically obtain an IP address as usual. Could you please provide the configuration page information of the first (faulty) port? We need to check its exact status. Thank you for your assistance.
It seems that the problem was caused by macvlan, which was associated with the first port. I make macvlan this with the following command:
ip link add host-macvlan link eth0 type macvlan mode bridge
ip addr add 192.168.1.225/27 dev host-macvlan
ip link set host-macvlan upF4-424 Pro
Took me a long time to gather enough courage (on two upgrades I had to Re-Initialize the system), but finally did it.
My F2-221 (my testbox) updated like a charm, quicky and without any issues.
The F2-225 refused to start properly. After login in the web interface just a blank screen. TNASPC said that TNASonline was not running.
Powered down, removed all disks, powered on and off, inserted disks and the system started up OK. Disk conversion went fine.
Happy this time no major issue. Will grab a beer - cheers Terramaster!
Other findings:
- Every time I go to System/Update the update check failed. When I refresh it says current system is the latest version.
- F2-225: Several (not all) shares seem to have disappeared. After recreating them all data within was present again.
Other findings:
F5-221 - TOS7.0.0765 - 5x4TB TRAID - 1x4TB Single USB - 2x4TB HwRAID1 USB
F2-221 - TOS7.0.0765 - 2x3TB JBOD - 1x4TB Single USB
If the version of the system you are currently running is 6.0.794, installation failures are usually related to the hard disk. Please perform a health check on the hard disk.ChadH42 wrote: ↑23 Dec 2025, 01:11 I have attempted to install TOS7 3 times on my F5-221 NAS. Every time it states that the install was completed but the system never re-boots to complete the install. When I try and manually restart it, the NAS is bricked! I lose the bootloader and have to rebuild the NAS each time.
Dear Support Team, please do not ignore the issue regarding Docker permissions. Thirty containers are unable to start, and the web server is down. We are ready to assist with testing, but such critical bugs must be addressed with hotfixes.
Disk health check shows all disks Healthy. I even swapped disk 1 & disk 2 (I have all 5 filled) and the same thing happened.CursaYang wrote: ↑23 Dec 2025, 08:40If the version of the system you are currently running is 6.0.794, installation failures are usually related to the hard disk. Please perform a health check on the hard disk.ChadH42 wrote: ↑23 Dec 2025, 01:11 I have attempted to install TOS7 3 times on my F5-221 NAS. Every time it states that the install was completed but the system never re-boots to complete the install. When I try and manually restart it, the NAS is bricked! I lose the bootloader and have to rebuild the NAS each time.
7.0.0309 - not fixed docker permissions problem !!!
Allready installed TOS 7.0.0299 then upgrade to 7.0.0309, I successfully the update all apps that recommended for update, but everytime I opened an apps from TNAS PC, there is always a delay before opening TOS Desktop and a warning always appears
Currently, the TOS system does not have built-in support for macvlan configuration, nor is it adapted for scenarios where macvlan and OVS are used simultaneously. If you need to continue using macvlan, please manually create it after completing all network configurations (including OVS setup), and note that it may need to be reconfigured after each network architecture change.DCCentR wrote: ↑23 Dec 2025, 01:39TOS settings:TMEmily wrote: ↑19 Dec 2025, 14:45Hello, thank you for your detailed description. The Open vSwitch enable operation itself does not change the DHCP or manual configuration mode of the port. The most likely scenario currently is that during the enabling process, the DHCP client process of the first port (LAN 1) encountered an issue, causing it to fail to automatically obtain an IP address as usual. Could you please provide the configuration page information of the first (faulty) port? We need to check its exact status. Thank you for your assistance.
It seems that the problem was caused by macvlan, which was associated with the first port. I make macvlan this with the following command:I bring macvlan up in the running config using these commands, but I don't save it in the config yet.Code: Select all
ip link add host-macvlan link eth0 type macvlan mode bridge ip addr add 192.168.1.225/27 dev host-macvlan ip link set host-macvlan up
Thank you for your understanding and support. If you encounter other network issues within the scope of system support, we are always here to provide further assistance.
