[ Jellyfin ] The Free Software Media System
Re: [ Jellyfin ] The Free Software Media System
Then maybe is a good option to reinstall your system and will see after...
powerQ
Singapore
Post by powerQ »
To enable hardware acceleration for Jellyfin with Intel N5095/5105(TM F2-423/F4-423), I found this video tutorial, watch it from 12".
https://www.youtube.com/watch?v=tWumbDlbzLY
That's achieved by running Proxmox VE on the NAS instead of TOS5.
With TOS5 is not possible to enable HW transcoding on F4-423 with the current kernel and parameters.
sanctimon
Post by sanctimon »
I have just attempted to install Jellyfin on a new installation of TOS5. No server control icon and no access. Same problem as @lincooln.
the start log reads:
17/03/23 05:26:26 The main volume is /Volume1
17/03/23 05:26:26  Config folder exist at /home/username/MOD_CONFIG/Jellyfin
17/03/23 05:26:26 Will run as user: jellyfin and group: media
start-stop-daemon --start -c jellyfin -b --exec /Volume1/@apps/Jellyfin/bin/program/jellyfin -- -d /home/username/MOD_CONFIG/Jellyfin/data -C /home/martin/MOD_CONFIG>
Happy to do a TeamViewer session for you to review.
sanctimon
Post by sanctimon »
While you are getting around to replying, just to note that I can make Jellyfin launch successfully in TOS5 by running command:
/Volume1/@apps/Jellyfin/bin/program/jellyfin -- -d /home/martin/MOD_CONFIG/Jellyfin/data -C /home/martin/MOD_CONFIG/Jellyfin/cache -c /home/martin/MOD_CONFIG/Jellyfin/config -l /home/martin/MOD_CONFIG/Jellyfin/log --ffmpeg /usr/local/ffmpeg/sys/bin/ffmpeg
However, command
start-stop-daemon --start -c jellyfin -b --exec /Volume1/@apps/Jellyfin/bin/program/jellyfin -- -d /home/martin/MOD_CONFIG/Jellyfin/data -C /home/martin/MOD_CONFIG/Jellyfin/cache -c /home/martin/MOD_CONFIG/Jellyfin/config -l /home/martin/MOD_CONFIG/Jellyfin/log --ffmpeg /usr/local/ffmpeg/sys/bin/ffmpeg
does absolutely nothing and this is, I suspect, the reason why Jellyfin won't start as expected under normal circumstances.
Spider
Post by Spider »
Hi Guys and girls,
I see allot of post on installing Jellyfin, but nothing on installing Jellyfin lol.
Meaning. I have all the required applications, but there is not instructions on the order of installation. I installed ModBase1, FFMPEG and Jellyfin. Are you suppose to do some configuration in Modbase1 and ffmepg before Jellyfin can be enabled. Right now when I try to enable it i get operation failed.
I have attached what I see in my overview.
Help!!!!
you received a reply already in the ffmpeg post (where you write initially)
Can you send the log files ? Or do you have teamviewer for a remote check session ?
Spider
Post by Spider »
Sorry @outkastm, I did add the log. I was not sure where to post my initial questions. We can use whichever post you want.
try to download and install version 10.8.9.2 ( will be up in 5 minute) and let me know if it work
Spider
Post by Spider »
I am not a paid member so it will about 4 days until I can download it.
