[ qBittorrent + CLI ] An open-source software alternative to µTorrent
jestermgee
Australia
Re: [ qBittorrent + CLI ] An open-source software alternative to µTorrent
Post by jestermgee »
Hoping to get some help
I have TOS6 and have used Qbittorrent for a few years without any issue.
The integrated search was searching several sources just fine until recently when it would only offer results from a single source torrents-csv and the "check for updates" in the plugin window no longer works.
I figured it was maybe outdated Python or qBt so I have tried installing the latest Python 3.8.12 and even tried 3.11 along with updating qBt to 5.1.2 however now the search produces nothing, not a single result so it appears now it is completely broken and no clue how that has happened.
Anything I can look into? Been quite a while since I had to even login to my NAS, it just ticks away doing what it should until now :(
EDIT: Will also add that since updating qBt to 5.1.2 all the detail tabs General/Tracker/Peers etc are empty when selecting a downloading torrent. Files still download but much of the application appears broken. I have tried restart of whole system and also TOS6 is up to date...
elfirwhite
Post by elfirwhite »
m4niekk90 wrote: 24 Jun 2026, 02:07
same
○ qbittorrent.service
Loaded: loaded (/etc/init.d/qbittorrent; generated)
Active: inactive (dead)
Docs: man:systemd-sysv-generator(8)
Jun 25 00:11:23 NAS systemd[1]: qbittorrent.service: Deactivated successfully.
Jun 25 00:11:23 NAS systemd[1]: Stopped qbittorrent.service.
Jun 25 00:17:23 NAS systemd[1]: Starting qbittorrent.service...
Jun 25 00:17:24 NAS qbittorrent[8927]: sudo: /usr/bin/sudo must be owned by uid 0 and have the setuid bit set
Jun 25 00:17:25 NAS qbittorrent[8869]: /Volume1/@apps/qbittorrent/bin/qbittorrent-nox starting
Jun 25 00:17:25 NAS systemd[1]: Started qbittorrent.service.
Jun 25 00:17:53 NAS systemd[1]: Stopping qbittorrent.service...
Jun 25 00:17:53 NAS qbittorrent[9140]: stop /Volume1/@apps/qbittorrent/bin/qbittorrent-nox: ok!
Jun 25 00:17:53 NAS systemd[1]: qbittorrent.service: Deactivated successfully.
Jun 25 00:17:53 NAS systemd[1]: Stopped qbittorrent.service.
jestermgee wrote: 24 Jun 2026, 09:20
Update to 5.2.2.0, search function and update plugins is working again and also General/Tracker/Peers etc are showing all the info.
elfirwhite wrote: 25 Jun 2026, 05:33
It seems that you are using the official version and not the community version
jestermgee
Australia
outkastm wrote: 25 Jun 2026, 06:38
Updated but still having issues.
Update plugins is still not functioning and seem to get few manually added plugins from here working:
https://github.com/qbittorrent/search-p ... ch-plugins
However most of these wont even install at all. I have now installed all available Python libraries 3.8, 3.10 and 3.11. Manually adding TPB for instance, no results returned and a month ago it use to work. I ended up deleting the whole list and the cache/nova directory but now I cannot even get the same plugins back I use to have working before.
I see in the log when I try and do the "plugin update":
(I) 2026-06-25T16:12:46 - Failed to check for plugin updates: Update server is temporarily unavailable. The connection to the remote server timed out.
But this has been happening for days / weeks and I do not have any VPN or anything in the way at the moment.
The update did fix the blank tabs tho
Little lost now on the plugin side. Is there a list of some plugins people use that are working? Many from the linked list are no longer valid and the ones that appear to still be valid just are not installing for me
jestermgee
Australia
Ok, think I am a little closer.
I switched my DNS to google for my NAS and it is now allowing plugins to be added and the update plugins has now auto-added plugins however I get this when searching:
Jackett: api key error! Right-click this row and select 'Open description page' to open help. Configuration file: '/usr/local/@APP_CONFIG/qBittorrent/data/nova3/engines/jackett.json'
I deleted this folder based on research to 'delete the cache' so I need to know how to install this back again. Following the details, i'm not having much luck and no idea what I did initially to get setup years ago.
m4niekk90
Poland
Post by m4niekk90 »
I've updated to 5.2.2.0 and it still does not work. Anyone has the same issue still ?
25/06/26 14:25:43 Will run as app user: torrent
All dependencies apps are installed
Could not create required directory '/usr/local/@APP_CONFIG/qBittorrent/cache'
25/06/26 14:33:18 Will use /Volume1 to store config files
25/06/26 14:33:19 The main volume is /Volume1
25/06/26 14:33:19 We are on TOS version 7
MODCONFIGPATHHOME=/home/myusername/MOD_CONFIG/qBittorrent
MODCONFIGPATH=/usr/local/qBittorrent/config
MAIN_VOLUME=/Volume1
HOME_VOLUME=/Volume1
25/06/26 14:33:19 Will run as app user: torrent
:mrgreen: F2-425 Plus :mrgreen:
TOS7 issue will be fixed asap. Wait for updated version
jestermgee
Australia
How do I address this problem when a search throws this message:
I see the config file but the jackett service does not appear to run so cannot get any API key via my server IP and 9117 port so unsure how to start the service
jestermgee
Australia
I also see this error in the startup log. Have tried with and without the Python311 installed, disabled the jackett entry and just no search works:
To control qBittorrent, access the WebUI at: http://localhost:6363
QIODevice::read (QSslSocket): device not open
Traceback (most recent call last):
File "/usr/local/Python311/sys/lib/python3.11/urllib/request.py", line 1348, in do_open
h.request(req.get_method(), req.selector, req.data, headers,
File "/usr/local/Python311/sys/lib/python3.11/http/client.py", line 1286, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/local/Python311/sys/lib/python3.11/http/client.py", line 1332, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/local/Python311/sys/lib/python3.11/http/client.py", line 1281, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/local/Python311/sys/lib/python3.11/http/client.py", line 1041, in _send_output
self.send(msg)
File "/usr/local/Python311/sys/lib/python3.11/http/client.py", line 979, in send
self.connect()
File "/usr/local/Python311/sys/lib/python3.11/http/client.py", line 945, in connect
self.sock = self._create_connection(
File "/usr/local/Python311/sys/lib/python3.11/socket.py", line 851, in create_connection
raise exceptions[0]
File "/usr/local/Python311/sys/lib/python3.11/socket.py", line 836, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
