TOS 6.0.500 Official Release
Yinnon
Re: TOS 6.0.500 Official Release
Post by Yinnon »
Hi
It seems that you have removed the download link for TOS 6.0.500
in any case I'm at version TOS 6.0.229 and it seems that the way forward is only through TOS 6.0.420 which is not exsists as well
Am I stuck for ever with TOS 6.0.229 ?
Will I need to make clean installation once an advance release will be available ?
Why you are not keeping the version history in order that users will be able to upgrade as needed ?
regards
Yinnon
terramaru
Post by terramaru »
It's look like diversion. Some process on NAS randomly resets permissions.
After install TOS 6.0.500 i'm everyday lost permissions for some random folders, and everyday i'm setup permissions manualy again and again.
Yesterday i'm wath the serial, go to the kitchen for 2 minuts, when return root folder "serials" is missing with all subfolders. Today morning i'm lost permission to root folder "films". But when i go to NAS to check permissions, it's was ok. I'm press accept, go to tvbox and see all root folders again.
By the way ... check box "allow permissions to all subfolders and files" don't work, do nothing. I'm check it many times.
And i can't set permissions to qbittorrent.
Lau6311
Malaysia
Post by Lau6311 »
Received the entry level F2-223 a few days ago loaded with TOS 5.145 and "is" with the latest (official) version, anticipating this device is in the compatibility list of final official release of TOS 6. Please anyone can advise. Thanks.
(General queries:
1. F2-223 first top 2.5G ethernet port is connected to 1G 8 ethernet ports switch. Can I connect my PC 2.5G ethernet port to F2-223 second lower 2.5G ethernet port at the same time. When possible, any settings are required? Reason: Hoping can transfer files faster by this way between NAS and PC. So far, can observe max files transfer about 100MB/s+ connected at 1G switch port. Satisfied. Currently using very old WD ex2 NAS.
2. Or FE-223 ONLY connected to PC for faster files transfer, on a temporally basis ?
3. Installed 2 NVME sticks to all SSD slots before initialization, resulted not able to setup hyper cache (main purpose) on SSD, selected RAID is JBOD. Planning to remove all Volumes + all ssd so to begin from fresh without hyper cache setup now and waiting for TOS 6 final release.)
Happy days to all...
F2-223, TOS 6.0.648, 2x8T N300 HDD Vol 1 & 3 (Singles)
1x1T Kingston NVME SSD Vol 2 (Single)
1x256G Hynix NVME SSD Hyper Cache (Balance Mode, 238G)
32G RAM
SteveHx
France
Post by SteveHx »
terramaru wrote: ↑25 Sep 2024, 07:35 It's look like diversion. Some process on NAS randomly resets permissions.
Same, and it's really boring because Plex System account is losing plex directory access every hour i guess.
please correct this fastly it was not the case in the beta version... :evil:
Immelmanntann
Post by Immelmanntann »
Hi. im on 5.1.145, want to update to 6th ver. What stepps should i make to success?
I mean, step by step 5.1.145->6.0.420->6.0.460->6.0.500? or i just can jump from 5.1.145 to 6.0.500.
Why i ask this, cause there's no 6.0.420 download link, so no way to update.
sergkris
Post by sergkris »
А где ссылки на 6.0.460->6.0.500???????... Что то я не нашел....
Immelmanntann
sergkris wrote: ↑25 Sep 2024, 18:43 А где ссылки на 6.0.460->6.0.500???????... Что то я не нашел....
Последнее предложение, нет ссылок, я потому и спрашиваю
EthanLiu
Post by EthanLiu »
Immelmanntann wrote: ↑25 Sep 2024, 20:50
Regardless of what model you are using, at this stage, only users who have participated in the TOS 6 beta test and have a TOS version of 6.0.460 or higher can update to 6.0.500. Only users who have participated in the TOS 6 beta test can use the 6.0.500 installation package.Please pay attention to the release of subsequent versions.
TMpraj wrote: ↑25 Sep 2024, 22:22
That is not the whole story, though. If you have a model that has not been visited by the "update fairy" (ie for which there is a downloadable installation (*.ins) file you should also not try to update according to earlier posts.
Then, in any case, Tos6.0.500 Official Release appears to be broken - (Sorry, includes some "inadvertent code modification") :oops:
We apologize for the inconvenience caused by an inadvertent code modification by our technical team, which led to issues in the permission module. Our testing team also missed these defects during verification. We will address these problems promptly and release an update soon.
Frustrated Beta Tester!!!
ellowsmile
Post by ellowsmile »
when to expect the new version 6.0?
F4-423
