[ Jellyfin ] The Free Software Media System
lincooln
Re: [ Jellyfin ] The Free Software Media System
Post by lincooln »
I am very grateful to you for your help.
Sorry for my bad English. I translate using Google Translate.
I wanted to say that I was able to look at the log only by ssh.
Thanks for suggesting additional parameters for smb I didn't know about this.
unfortunately I don't have any such options in TOS.
the log file states that the program must be run as the Jellyfin user and the media group.
Here is the contents of the logfile
17/02/23 10:57:57 The main volume is /Volume1
17/02/23 10:57:57 Config folder exist at /home/lincooln/MOD_CONFIG/Jellyfin
17/02/23 10:57:57 Will run as user: jellyfin and group: media
17/02/23 11:03:16 The main volume is /Volume1
17/02/23 11:03:16 Config folder exist at /home/lincooln/MOD_CONFIG/Jellyfin
17/02/23 11:03:16 Will run as user: jellyfin and group: media
17/02/23 11:12:44 The main volume is /Volume1
17/02/23 11:12:45 Config folder exist at /home/lincooln/MOD_CONFIG/Jellyfin
17/02/23 11:12:45 Will run as user: jellyfin and group: media
screenshot support & help attached.
For samba just expand the Advanced field.
Can we have a TeamViewer session for Jellyfin?
lincooln
Post by lincooln »
unfortunately TeamViewer does not work in Russia I am very sorry.
do you have the emby app installed and running ?
lincooln
Post by lincooln »
No. i don't have emby or plex
everything I have installed.
if i can't connect via SSH to your NAS i don't know how can i help you...
lincooln
Post by lincooln »
maybe i need to reinstall my TOS system?other users are not complaining. So it's just me who has the problem? I am a new user terramaster. Anyway, thank you for taking my time. I plan to add a second hard drive soon. And I'll try to reinstall the system again. and then I'll give feedback.
no need to reinstall it, i will upload a new version wit more info in the log
do you have log file inside Jeelyfin/log folder ?
Download again the app, install it and send me the log
lincooln
Post by lincooln »
Outcastm I apologize for disturbing you.
I found my problem.
I don't know why, but I have the plex app installed.
I do not see it. no desktop shortcut. no folder in explorer. there is no data on this.
but I had to go to the application center. find plex in it. and I see that this application is installed. it doesn't work either. startup fails. also impossible to delete. error again.
Perhaps this is from my past experiments. I just got acquainted with the TOC system and installed various applications to see how it works. after I reinstalled the system to TOC 4 version and updated to TOC 5.
Once again I apologize. And thank you for helping newbies.
