TOS 6.0.673 (X86) is Released for Update
Alby87
Italy
Re: TOS 6.0.673 (X86) is Released for Update
Post by Alby87 »
I've tried to search for the update from the control panel, but it finds only the 650 (I'm using the 648). I need to go trough every update? No possibility to skip? Thanks!
antonkholodov
Post by antonkholodov »
Подскажите пожалуйста как и где можно скачать обновление tos 6.0.673. Через сам NAS не могу скачать обновление
Интернет на NAS есть, я к нему могу подключится удаленно
Alby87 wrote: ↑06 May 2025, 14:44
antonkholodov wrote: ↑06 May 2025, 15:48
Can you identify your nas type and Bios number?
antonkholodov
Модель F2-221, версия BIOS/initBoot MAPL0304V22
therealguppy
Post by therealguppy »
This Update Broke my OPEN VPN by file config. Unable to reconfigure just keeps erroring out. :cry:
Alby87
Italy
Post by Alby87 »
Gremlin wrote: ↑06 May 2025, 16:21
MAPL0303V21, F4-421
Gremlin wrote: ↑02 May 2025, 08:15 Another mysterious issue: Left F2-221 running for a few days with only auto power-off and power-on plus TFM backup scheduled to run. Last success was (edited Previous Day)
Noticed this evening that auto power-off did not function. No response from web browser. No response from hdmi console (output or input) [Ctrl/Alt/Del], no email notifications. Device appeared to be visible in TNAS-PC but could not login. TNAS-PC requested new IP - Non functional. Had to resort to long-power-off from panel. Wake-on-lan non-functional. System Report prepared & will take a look tomorrow.
(System restart from power switch appears ok.)
Sorry to be quoting myself BUT....
This happened again. NAS completely unresponsive. Tried disconnect/reconnect network cables/HDMI/USB but only last-resort power button 'effective'. {No hdmi display, no response to keyboard Ctrl+Alt+Delete}.
Going to try 6.0.685{Beta}
Patryn
Netherlands
Post by Patryn »
Dito on the prob. Backup-logout-login but "Unknown user" -> shares still available until reboot, after reboot 502 Bad Gateway error on the login page and no more shares, that last one might be important, because without reboot you at least could backup something if needed.
After reboot telnet (yeah, don't ask) and SSH still available with normal credentials.
Alby87
Italy
Post by Alby87 »
Still seeing 650 as maximum update available. I have to go to 650 to get 673 starting from 648? Can not directly update?
vignatiev
Post by vignatiev »
I’ve found one more bug. If I set any date format with dots instead slash, then I see NaN instead numbers.
F4-424
