TOS 6.0.535 (X86) is Released for Update
EthanLiu
Re: TOS 6.0.535 (X86) is Released for Update
Post by EthanLiu »
malyzajac wrote: 23 Nov 2024, 02:12
As you said, after updating, you can use the "Restore Factory Settings" function to restart the device to reinstall your system.
malyzajac
Slovakia
Post by malyzajac »
Will be both packages INSTALL and UPDATE released for TOS6 in the future as it is for TOS5?
Tom
Ireland
Post by Tom »
Is there any update on UPS issue where it only works for 30mins to 1 hour then the checkbox for Enable UPS Support becomes unticked and if you try to enable UPS support it can't detect the UPS until the NAS is rebooted ?
zonatar
Italy
Post by zonatar »
I still have issue with my files permission, is possible to install the 0.500 version on the 0.535?
ColaChen
Post by ColaChen »
zonatar wrote: 29 Nov 2024, 17:58
Hello! We can install version 6.0.535 of the system, and if the permissions are not inherited, we can modify the permissions!
This is mentioned in our update note:
"Warning!
This version is not compatible with the Beta version's permissions.If permissions cannot be inherited after the update, you need to temporarily assign other permissions and then reset them to the ones you need."
TMcola wrote: 29 Nov 2024, 19:47
You can say that as many times as you like, but people will still ignore it ;)
perezil
Post by perezil »
I will need to manually install TOS6. Can you please provide a link where can I download the file?
perezil wrote: 30 Nov 2024, 02:07 I will need to manually install TOS6. Can you please provide a link where can I download the file?
Not much to go on there.
But, I think you are out of luck at the moment. The latest version for an F4-210 is Tos4.2.44 available here:
https://support.terra-master.com/downlo ... uct=F4-210
although, I suspect you already know that.
mrslother
Post by mrslother »
Problem with SSH and authorized_keys.
Just received u4-423; tried TOS5, updated authorized_keys file with my pub keys. SSH'ing worked great using keys.
Decided to try TOS6 so I factory reset then manually installed TOS6 then updated to latest: 6.535.00158.
For the love of God, I cannot get authorized_keys to work. I can ssh in with password, but no matter what I do with the same authorized_keys file I previously used, it always requires the password.
I've tried various options found in this forum, but nothing worked.
Please help!
TMlinda
Post by TMlinda »
mrslother wrote: 30 Nov 2024, 06:50
Since you have switched to TOS6 system, the previous authorized_keys file may not be applicable. You can try to regenerate a new authorized_keys file.
